I often use the "Find All Instances" option from the right-click menu when clicking on a VI's icon to find all callers of that VI. However, it regularly comes up with fewer hits than the "Find Callers" option. In this case, it came up with 0 hits:
However, if I navigate to the VI in my project (ctrl+shift+e) and then right-click on it and select "Find -> Callers" it will actually find the callers:
I've never understood this discrepancy, and I see it regularly. Perhaps this is more a bug than a feature request -- but I do feel that if these callers are consistently findable from through one of these mechanisms, they should be consistently findable through both.
Note: in the case above, if I do open the VI (after finding in using "Find Callers"), it will then be found if I "Find All Instances...". But if I close the VI, it's no longer found using "Find All Instances".
