BowenM
"Insert into map": Pass map wire through correctly when using QD
Status: Already Implemented
Available in LabVIEW 2020 and later
I often select a wire constant and use QD (ctrl-space, ctrl-i) to add things onto wires. When used with "insert into map", QD auto wires incorrectly.
6 Comments
thols
Active Participant
It works for me on LV 2021 SP1.
One time of 20 I tried this, I could see the wire was broken a fraction of a second before it was correct.
(I would call this is a bug report and not a feature request)
Certified LabVIEW Architect
wiebe@CARYA
Knight of NI
LV2020 SP1, I think?
I concur.
thols
Active Participant
"LV2020 SP1, I think?"
Yeah, me wishful thinking
crossrulz
Knight of NI
Broken in 2019 SP1.  Works in 2020 SP1.  So I would say this idea should be closed as "Already Completed".
BowenM
Active Participant
My apologies - I didn't try it in 2020, and I don't recall seeing the change in patch notes. Agree that it should be changed to completed.
Darren
Proven Zealot
Status changed to: Already Implemented
