I was reading this idea (Inline "Space constant.vi"), and I initially misread the title as "in-line space constant." This got me thinking... what if we could concatenate string constants on-wire? Give string constants an input which, if wired, concatenates the constant with the input. If it's not wired, it acts as a standard constant.
Since a picture is worth, well, a lot more words than I'm willing to type, here's what I'm thinking:
(the current method can also use Format Into String nodes)
Most of the time, Format Into String is my VI of choice for essentially any string building, but once in a blue moon I'm looking to do something like the above. So it's a pretty limited use Idea. But someone might like it, so I figured I'd post it.
What does everyone think?
