Graphs have a plot images property that allows us to draw anything we want on the graph area using picture commands. (example 1, example 2).
I propose to have a similar property for the front panel (or specific pane) area that would allow us to address any pixel and use picture commands at run time (e.g. Plot Images.Front to temporarily circle an area to guide the user or place a huge red warning text across the entire panel in case of a malfunction. We could use Plot Images.back to change a logo or show a connection diagram picture, or similar. (currently, we only have the limited background image property)
This should be entirely cosmetic and should not interfere with the operation of controls, etc.
Here's how it could look like at run time...
