oenk
"Restart LabVIEW" menu item
Status: Declined
National Instruments will not be implementing this idea. As a workaround, you can write your own tool to restart LabVIEW. You can add items to the pull-down menus in LabVIEW by following the procedure listed here. In this tool, you will use the Restart Method
How about a "Restart LabVIEW" menu item?
When developing C# add-ons for LabVIEW I sometimes need to restart LabVIEW just to get the current loaded .NET assembly out of the LabVIEW AppDomain. It would be nice if there would be a "Restart LabVIEW" menu item so I don't have to exit and restart manually.
Cheers,
Christian
13 Comments
gsussman
Active Participant
To respond to AQ about the need to restart, I do find that periodically I need to S/D and restart LV.
 Granted that may only be after a 48 hours or so of development on a large project (Windows,RT, & FPGA), but it does seem to free up memory and system resources that simply closing down all of the open projects does not.
I really don't think that it is a big enough issue to warrant spending R&D resources on. Just my $0.02
Greg Sussman
Sr Business Manager A/D/G BU
TimBotsM
*I know a bit late bit still valid*
Another reason for a restart button is to unload (deleted) classes in memory.
If you delete a class it's not unloaded but moved to the "Dependencies\Items in Memory" folder. However since it's lost all connections to the project it always results in a broken run button.
Also if you dynamically load plugins (HAL) these won't be unloaded until you restart LabVIEW.
Darren
Proven Zealot
Status changed to: Declined
