As briefly outlined here already, The "File...Save All" menu entry is currently very dangerous and can lead to unintentional damages that are difficult to repair.
The "Save All" entry is very close to the "Save As ..." entry which looks similar, but is used if we don't want to overwrite any existing VI, i.e. exactly the opposite functionality! A small inaccuracy of the mouse can easily select one for the other, with potentially damaging results.
If you don't believe me, create a new VI and place e.g. exponential fit on the block diagram. Double-click the subVI for editing and move one of the terminals by a few pixels. Now go to the toplevel VI and select "file...save All". Notice that the system VI has been re-saved without warning with the changes you just made. If the changes would have been more serious, the entire LabVIEW installation would be corrupted, because it now contains a subVI with altered or broken functionality.
Here's how the suggested default confirmation dialog could look like.
Idea Summary: The "Save All" menu item should be renamed to "Save All..." and should open a confirmation dialog before the final action is carried out.
