DavidJSzwer
"Select all in cluster" right-click menu
Status: Declined
It is currently difficult to select all the contents of a cluster without selecting the cluster itself, on the front panel or a block diagram.  This is especially true if the contents are themselves clusters or arrays; a marquee selection often picks just a few elements from them.  I suggest having a command on a cluster's right-click menu called "Select all cluster contents" that does exactly that.  Alternatively, or in addition, this could be a shortcut such as Ctrl+Shift+A (to match the existing Ctrl+A for selecting everything on a front panel or block diagram).
An example situation where this is useful is when you place a TypeDef constant on the block diagram, and want to show the labels on each element of the cluster, to help you fill in the values.
4 Comments
crossrulz
Knight of NI
Your "Show All Labels" can be done with this shortcut: Expand Cluster Constant.llb
DavidJSzwer
I'll take a look, thank you!
Darren
Proven Zealot
Status changed to: Declined
KKMurphy
I agree this would be helpful. Not sure how to get this reopened since it was "Declined".
