a trueselect function, more powerfull
Why not just Build Array and then index it?
- Build_Array increases unnecessarily the used memory..
- Two functions, just to select an input, unnecessarily overload the block diagram.
A little bigger solution, not too inefficient (just 1 extra buffer)...
In any case I like your proposal, so kudos.
I created a subVI for a multiplexer for my first project, which was probably not the best of designs. A multiplexer is useful feature to have on the functions pallet.
What about a demuliplexer?
Similar to this old idea:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Growable-Multiplexor-or-multi-Cases-selection/idi-p/10...
my last xnode to solve this!
ouadji,
the last version (ver4)
the fourth message
