9 | |
3 | |
3 | |
2 | |
2 |
Currently, the "Tab" key is not individually mapped to an action for Block Diagram interactions; my suggestion is to use it to swap between "control", "indicator" and "constant", in the same way we already do with the options of the right-click menu "Change to Control/Indicator/Constant".
As an example, having selected a control on the BD, by just pressing "Tab" we would transform it into an indicator, a second press to a constant, and a third one would bring it back into being a control.
I understand this is a simple thing, but personally, I feel this ends up being one of the most repeated actions we end up taking as developers and I believe it would be intuitive to map it to a familiar key to many of us - tab.
Thanks all,
Cris
