5 | |
2 | |
2 | |
1 | |
1 |
Dear NI,
Please fix LabVIEW so that when you right-click on a wire on the block diagram the menu pops up immediately, not after 1 second. Also, while you are fixing that, it would be great if you could fix the speed it takes to open a control/indicator properties configuration dialogue.
As far as I can recall these were fine in LV 7, but sometime after that itall started to get a bit sluggish.
Thanks!
