spent half a day today figuring out how to get my icon that was created in LabView's icon editor over to the icon editor in the Application builder. After much trial and error the only method I found was to select and copy the pixels to the clipboard while in the LabView icon editor, then run the Application builder and open its icon editor and then paste the contents of the clipboard into it. Some pixels change colors when doing this. Why doesn't the LabView icon editor allow one to save an icon in the .ico format that the Application icon editor requires? Seems logical to keep the same icon for your compiled app instead of having to create a new one in the App Builder. It would be even better if the Application Builder would just automatically load the icon from the startup VI by default, but allow the icon to be changed in Application Builder icon editor if desired.
