10 | |
3 | |
2 | |
2 | |
2 |
I always use "Find All Instances" for searching where a subvi / control is used.
When looking into code that is locked (read-only because of being under source control), this option is missing!!.
I don't think it should be a big problem to enable the right-click menu on a locked vi...
Now available in LabVIEW 2023 Q3
