10 | |
3 | |
2 | |
2 | |
2 |
when you place a label in the front panel, this is a new object, in decorations list, but their order number is indexed the first, and all old decorations are renumbered, if you have some programatic control about these decorations, you need reorder your calls.
Solution:
working in similar way of the controls, the last put, it has the last number plus one, and having the possibility to reorder the decorations in de FP in developer interface.
