| User | Kudos |
| 11 | |
| 7 | |
| 6 | |
| 5 | |
| 4 |
I'm a great advocate of commenting code, but with the graphical nature of Labview, you need space on your block diagram to add in a post-it giving your comments. That's great if your block diagram is nice and spread out, but (perhaps due to poor planning/programming) i'm often finding myself getting limited on space. Adding comment labels all over the place takes up even more space and results in the whole block diagram exploding to an often impractical size.
Wouldn't it be nice to be able to do an Excel-type tool-tip, where comments will be hidden until hovered over with the mouse?
Instead:
hover with mouse ->
