be able to unlock an object locked onto a wire
like this :
l
This is one of these "intended" LabVIEW features that you will have a hard time convincing NI to change... 🙂
BTW, it can be worse than what you are describing, as I discussed here.
Right click clean up wire will unlock the indicator from the wire.
i didn't know this trick
thank you Ravens Fan
Or just click and drag/keyboard the wire itself instead of moving the terminal.
I didn't know this one either! ()
thank you Aristos Queue.
