8 | |
6 | |
4 | |
3 | |
2 |
Right now with VIAnalyzer, there is a built-in test for
General >> VI Properties >> Built Application Compatibility.
This test is supposed to check for issues related to execution as a built application (running in RunTime Engine)
However, it does NOT do any checks against MScripts for the MScript node functions that are not supported as part of the runtime engine, or that behave differently in runtime engine vs development environment. (generally identified by the yellow exclamation mark triangle in the dev environment)
This VI Analyzer test should be updated to include MScript node checking for compatibility against built application / runtime engine.
