LabVIEW Interface for Arduino Discussions
5003 Error
So I have been using the following code to control some dc motors with h bridges successfully. All of a sudden, I am getting a 5003 error...it seems to be happening when I try to write zeros to the ports on either side of the loop. Any idea what may be wrong? It's happening for another code I have using a different type of h bridge.
(4,076 Views)
I would start by trying to simplify the code. Does it happen when you run some of the examples? Can you get a simple VI that replicates the behavior?
Kevin Fort
Principal Software Engineer
NI
(3,377 Views)
We actually figured out that it was writing to the port outside of the while loop...we didn't really need it so we took it out and the code works now
(3,377 Views)
