LabVIEW Interface for Arduino Discussions
8 channel relay driver shield for Arduino (i2c problem)
Hi there I build the attached VI to communicate with the 8 channel relay driver shield for Arduino. I tested whether the communication between my pc and Arduino uno is working by building VI to control pin 13 on the Arduino and it works well. I also used the Arduino software (Wire) to control the channels of the relay driver shield and it also works well. I think am doing something wrong when I addressing the shield into my VI. Can anyone help me with setting the right address into my VI? I attached the quick start guide which show how to address the shield via i2c and also I attached the VI I am working on. Your help is appreciated Thanks
(5,393 Views)
Accepted by topic author abrka2011
The address that you use depends on the "I2C Address Jumpers" as shown on page 2 of the PDF document.
I have attached a VI that essentiall duplicates what the example program does but in addition, allows you to have more than one relay active at a time.  Let me know if it does or doesn't work or if you have any questions.  It assumes that the address is 0x20.
(4,435 Views)
Hi Nathan
It perfectly works.
Thank you very much for your time and effort.
Adel
(4,435 Views)
