LabVIEW Interface for Arduino Discussions
Analog Read Pin VI
Hi all,
I'm new to Labivew and Arduino but hoping to incorporate both into my classroom. The Uno I have is functional; I've had some success with it already in the sketch editor. I'm hitting a wall with the interface, though.
I downloaded VISA but probably overlooked something in the setup. I can't get this Analog Read pin VI to work (from the examples). After setting up a constant on the Init.VI to specify the correct COM port, I hit Run and I can see the TX/RX lights flashing on the Uno. The data from the analog pin is not being read, however. The meter doesn't move.
Hopefully it's something simple I'm overlooking. I'd really like to move forward and explore LIFA.
(4,406 Views)
Does the blink VI work?  That is the first one that I would recommend testing.
(3,321 Views)
