LabVIEW Interface for Arduino Discussions
Analog read pin error 55
Hello
Buy your suggestions I install LINX and  arduino works with some examples by I modified the example Analog read pin, remplace the arduino module by LINX,but it doesn't work can you a proposition for me.
(4,839 Views)
Since you are using LINX and this is the LIFA discussion forum, you should post your issue on the LINX forums.  When you do post, you will want to provide more details about your situation.  Things like which Arduino you are using, etc.  The more details the better.
(4,282 Views)
You can't use LIFA examples with LINX and LINX examples with LIFA. When Using LINX use the Analog Read 1 Channel.VI LINX example to read an analog pin.
hrh1818
(4,282 Views)
Thanks Nathan
(4,282 Views)
hello hrh1818, thanks..
(4,282 Views)
