LabVIEW Interface for Arduino Discussions
Analog read port and comunication with SPI device
Hello, I'm reading two ports of the analogport and at the same time I want to send a data for the SPI but when I do this the analog port doesn´t work.
(4,410 Views)
Have you tried using LINX instead of LIFA?  LINX is the only Arduino-LabVIEW software that is actively supported.
Does the SPI device work if you remove the Analog Read Port?  Are there any errors coming from either the Analog Read Port or the SPI VIs?
(3,307 Views)
hi, I´ve not tried to LINX and yes, always that i want to send a data for the SPI the analog port doesn´t work but the SPI works and if i stop to send the data for the SPI and after a time the analog port works.
(3,307 Views)
