LabVIEW Interface for Arduino Discussions
Arduino Analog port to read multiple analog pins
Can anybody please tell me how to use analog port and distinguish values of different analog pins using that port?
(7,919 Views)
I suggest you use LINX..  The example Analog read N Channels.VI is included in the installation software.   LIKFA is no longer supported by National Instruments.
hrh212
(7,325 Views)
Is there any delay between reading multiple channels simultaneously using LINX?
(7,325 Views)
Accepted by topic author pk4
Arduio UNO boards have only one ADC, so yes there will be a de;ay between readings.  The conversion rate for Arduiuno Uno boards is approximately 10,000 samples per second.
hrh212
(7,325 Views)
