LabVIEW Interface for Arduino Discussions
Arduino Clone
Hi Guys Newbie Here..
I'm just wondering if is possible to use arduino toolkit for arduino clones.
Since there are only three boardtype selection (Uno, dimue & Mega), is it possible??
Anyone here already tried??
(6,731 Views)
I tried with my friend's arduino clone last week.Consistently, it was worked.
(6,034 Views)
Since you are new here, it's important that you know that LIFA is very old and no longer officially supported.  It has been replaced by LINX.
http://www.labviewmakerhub.com/linx
You can post on the LINX forums for LINX support.
(6,034 Views)
Didnt worked in my Gizduino (arduino clone)
when i upload the LIFAbase.ino it says chip not supported..
Any possible solutions ?
(6,034 Views)
sir is it still possible to interface my gizduino(arduino clone) using LINX?
(6,034 Views)
I don't see why it wouldn't be possible if you are able to run sketches compiled with the Arduino IDE.  You might need to modify some code to get it to work but I can't know for sure because I don't have the device that you do.  I'd first recommend that you simply try it.  If it doesn't work, search the LINX forums to see if somebody else has tried it.  Lastly, you can post on the LINX forums and see if anyone has an insight.
(6,034 Views)
