LabVIEW Interface for Arduino Discussions
Arduino Continuous Sampling.vi doesn't give the VISA Resource free
I'm using an Arduino Leonardo Board and it's working fine with some other sample vi's I tried before.
Now I want to continuous  sample data on an analog Pin, but it only work once.
If I stop the VI, it seems like the COM Port or VISA Resource is still in use.
I can see the "?" in the VISA interactive control porgram.
A reboot always helps.
What is the difference in this VI and why is it behaving like this?
I've attached a working VI (Graph Data Mag.vi) and the VI, based on the continuous sampling VI, which causes the problem (Strom_mess2.vi)
Thanks in advance!
(3,726 Views)
I just want to say, that I build a new project, not based on this example.
This is working fine.
I think the problem with this sample is, that the arduino stays in the coninuous sampling mode and need to be reset.
(3,492 Views)
