LabVIEW Interface for Arduino Discussions
Arduino Ethernet connection with labview
I want to find out if it is possible to connect arduino to a wireless router and sending commands from labview?
Thanks.
Message 1 of 9
(16,267 Views)
No.  LabVIEW communicates with Arduino via a serial connection (USB, XBee, etc.).  To use it wirelessly, you would need to use XBee or some equivalent wireless serial device.
Message 2 of 9
(8,312 Views)
I wouldn't say 'No', outright like that...
I will try an look into this as I think it might be a useful feature.
Dale
www.GorillaBuilderz.com
Message 3 of 9
(8,312 Views)
There are WiFi shields available for Arduino.  See:
<http://www.sparkfun.com/products/9954>
So yes it is possible to send commands to and receive data from an  Arduino board via a wireless router.  But LIFA does not have this capability at the present time.  You would need to write code to enable this capability.
Howard
Message 4 of 9
(8,312 Views)
What hrh1818 said is what I meant.
Message 5 of 9
(8,312 Views)
get an ethernet shield for the arduino......
i am working on that right now, UDP communication between the arduino and labview... so far its been succesfull
CLAD, CTD
Message 6 of 9
(8,312 Views)
Hey buton,
can you post the code for it here? This is exact what I am searching for. Thank you.
Message 7 of 9
(8,312 Views)
How about the blutooth shield: http://www.amazon.com/gp/product/B007BYI172/ref=ox_sc_act_title_2?ie=UTF8&smid=A27ZR3QEE0TMAB
Does this work like a COM and communicate with LIFA?
Message 8 of 9
(8,312 Views)
Look this https://decibel.ni.com/content/thread/16861 (LIFA - Ethernet)
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 9 of 9
(8,312 Views)
