LabVIEW Interface for Arduino Discussions
Arduino Labview error 5003
i have a Problem with Arduino and  Labview  i have every Time the error 5003. I hope someone can help me.
(8,072 Views)
Hi,5003 means that Labview does not see your Arduino.Have you installed LINX on the arduino yet?Install LINX and make sure you have a close serial at the end of your code. Make sure it gets to run even if you have errors in between start and end.Barddya
To: barddya <barddya@yahoo.com>
Sent: Thursday, December 17, 2015 7:56 AM
Subject: - Arduino Labview error 5003
created by falkii in LabVIEW Interface for Arduino - View the full discussionHello,  i have a Problem with Arduino and  Labview  i have every Time the error 5003. I hope someone can help me.  Reply to this message by replying to this email -or- go to the message on Community Start a new discussion in LabVIEW Interface for Arduino by email or at Community
(7,101 Views)
I programm with Lifa, i have Tested Linx too but i have no idea how i can programm the dht22 with Linx.
(7,101 Views)
Neither LIFA nor LINX has native support for that sensor but LINX, in general, will be better to use.  LINX has a much better way of integrating custom functions so that you can add sensors like the DHTXX sensors using existing Arduino libraries.
Have you searched the LINX forums?  I know people have worked on getting at least one of the DHTXX sensors working.
(7,101 Views)
Yes i have searched the linx Forums i have found something about the dht22 but it does not work
(7,101 Views)
Hallo i have news it works with dht22 but when i add digital write pins the 5003 error comes back hope someone can help me
(7,101 Views)
