LabVIEW Interface for Arduino Discussions
Arduino UNO R3 Connection problems
Does this happen when no Arduino is connected to the PC?
Is this a Windows computer?  What OS Version?
Does LabVIEW hang at this block until you forcefully kill it (useing task manager)?
-Sam K
LIFA Developer
Message 11 of 15
(2,523 Views)
Yes this also happens when no Arduino is attached. Using Windows 7, but I get the same problem on XP, and on both the 32bit and 64bit versions. I am still able to connect using the arudino coding platform, just not labview.
I have a new development as of today. If I leave labview running for over half and hour it eventually connects. Maybe it's a timeout issue? I've tried playing with the timeout settings but it hasn't helped so far.
Message 12 of 15
(2,523 Views)
Bumping with high hopes?
Message 13 of 15
(2,523 Views)
problem has been solved. I have  done few changes in "LabVIEWInterface.ino" file.
as shown in the image i have just comment d  checksum part,as some how, check sum condition is not solved.
After doing that there is no error. and  arduino is easily synced to labview.
Message 14 of 15
(2,523 Views)
Hi, i have the same problem I comment also the checksum but no success.
can someone help me please
Message 15 of 15
(2,041 Views)
