LabVIEW Interface for Arduino Discussions
Arduino Uno + Laser distance sensor + Labview
Hello everybody,
I doesn't have suffiecient knowlege about labview interface. So kindly help me to find the distance using laser sensor using arduino uno and labview interface
(5,390 Views)
LIFA is outdated and no longer supported.  You should not consider using LIFA.  Instead, you can consider using LINX.  So, I'd recommend posting on the LINX forums.  When you do post, you'll need to provide more details about your sensor, ideally, you should provide a link to the sensor's datasheet so that we can determine the feasibility of using the sensor with Arduino and LabVIEW via LINX.
http://www.labviewmakerhub.com/linx
(4,820 Views)
