LabVIEW Interface for Arduino Discussions
Arduino Uno r3 not working with LabView 2013. NI LIFA file has a bug.
Im having a problem with LabView 2013 and Arduino working..  My  LIFA file has a bunch of robot tools that shouldent be there and when i try to delete them messes it up more. Then I have to delete the whole file and download the software again.
I understand it works fine for the previous versions of LabView. Is there something i can do to fix the problem?
(4,580 Views)
LIFA is not different between different versions of LabVIEW, it works on LabVIEW 2009 the same as 2013.  What "robot tools" are you referring to and what file(s) are you modifying?  Could you post the code to which you are referring to as "robot tools"?
(3,881 Views)
This is what i get when I upload LVIFA_BASE file
(3,881 Views)
I don't really understand.  I don't see anything in the image that relates to the original topic.  However, I do notice two things.  If you are using LVIFA_Base.pde then you are using an outdated version of LIFA.  You should upgrade to the latest version of LIFA whose sketch is LIFA_Base.ino.
(3,881 Views)
