LabVIEW Interface for Arduino Discussions
Arduino blink LabVIEW start
Good morning, I have a problem conecting Arduino and LabVIEW. When I run in arduino's stardard software the blink example it works as it should.
However, when I run LabVIEW and I try the same it doesnt work, some leds light up (TX,RX,,L,ON), but the 13 leds doesent blink at all.
(I think I have installed all correctly but now I have doubts)
Thanks for your help
Buenos días. Tengo un problema con Arduino y LabVIEW, cuando ejecuto arduino en su software normal el ejemplo de "blink" me funciona correctamente pero cuando ejecuto LabView y pruebo este mismo ejemplo no me funciona aunque algunos leds si se iluminan (TX,RX,,L,ON)
Muchas gracias por su ayuda
(5,070 Views)
Hey ignaciogabaldon,
Can you give us more details on what you are doing?  Did you upload the LIFA firmware?  Did you get any errors or warnings when you did?  What LV code are you running?  do other examples work (such as the analog read example?)  What type of Arduino are you using?
The more information you can provide the easier it is for us to help you.
Thanks!
Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker group on Google Plus.
(3,850 Views)
