LabVIEW Interface for Arduino Discussions
BEGINNER connection : Labview + Xbee
Hi komangwiswakarma
I try to do your method .But I can't success!
default program ↑
modify the program ↑
Am I doing wrong ?
Any answer thank you very much.
Message 11 of 23
(5,325 Views)
hai 冠婷
did it successfully uploaded into the arduino? if so, then the code is not the problem. otherwise, could you show the labview display?
Message 12 of 23
(5,325 Views)
komangwiswakarma
I tried again, I'm sure that the code is uploaded to the Arduino.
However, it is not successful, get the same error code -1073807360.
Please help me to confirm that the code is correct.
My hardware is Bluetooth,  can use your method?
Thanks for you answering.
Message 13 of 23
(5,325 Views)
komangwiswakarma,I used to try to the VISA modules the COM10 do communications.
The work is successful.On behalf of the COM10 is communicate properly.
The VISA default baud rate is 9600.
Message 14 of 23
(5,325 Views)
Hi,冠婷. Have you resolved your problem?
Message 15 of 23
(5,325 Views)
i have the same proplem but i can' slove it i try to change the code labviewinterface.h but not work
Message 16 of 23
(5,325 Views)
Hey castus,
Can you please tell me that  what function set you are creating for the xbee. I did the same thing the xbee connected to my laptop is as a "cordinator AT" and at the reciver end which is connected to the arduino that i setup as "router At" .  i tried by changing the baud rate of the base file but still i have the same error as u were getting earlier. Please help me out m too stressed and i do not any other soft other than labview to create the interface.
Message 17 of 23
(5,325 Views)
hello there, i use two arduino uno nd two xbee 1wm for my final projects, but my sketch on Labview is not running if i combine the xbee. what wrong. is in the sketch or not? this is my sketch. are you all can help me. thaks.
Message 18 of 23
(5,325 Views)
hola disculpen me pueden ayudar hacer una camunicacion labview arduino y xbee agradesco su atencion soy nuevo en el foro . lo quiero hacer con una xbee pro para medir la temperatura.
Message 19 of 23
(5,325 Views)
修改
Message 20 of 23
(5,300 Views)
