LabVIEW Interface for Arduino Discussions
BUGS: LVH LINX/LIFA NANO V3 Error 5003 USB FTDI/CH340/PL2303
Labview 2014 F2 VISA 14.0.1 Win7(tried VISA 5.4 on another machine with same results)
Official Nano V3 with FTDI usb and Arduino Nano V3 with CH340 USB. (Verified in Device Manager and NI-MAX)
I've tried using the built in nano USB Driver CH340, and also a separate PL2303 Module.
Drivers for FTDI FT232RL/CH340/PL2303 usb installed and work fine and upload sketches with Arduino 1.6 IDE
I logoff windows when switching between USB controllers, or else sometimes it won't properly release them, and thinks they are busy.
Firmware uploads in 25 seconds with the PL2303 with no errors(added DTR pin and .1uf Cap to pin 2 to add reset)
When using FTDI/CH340 it uploads in 10 seconds no errors(1st pic)
When I go into the VISA Test Panel, and change any option(eg timeout 20000) after applying it,NI-Trace writes and gets the value(20000) fine, but after closing the test panel and reopening it, all changed values are reset?(2nd pic)
Anytime I try to run a program with proper COM port set, after either Firmware upload, I get no VI-Trace Errors, but I get Error 5003:(3+4 pics)
Installed LIFA package and LIFAbase.ino but it will not run gives error 5005 with LIFA blink example.
Nano V3 seems to not be compatible with LINX or LIFA.
(5,469 Views)
For support for LINX, please post in the LINX forum.
(4,041 Views)
Sam is a really busy person and can't respond to everybody within hours of them posting.  He has a full-time job while creating and supporting LINX in the evenings.
(4,041 Views)
