LabVIEW Interface for Arduino Discussions
Can't Get example programs to function.
Disclaimer:  I am a complete newbie to Arduino and LabView.
I just received the Arduino Uno R3 and Labview student Version 2011 from Sparkfun.  I installed Labview along with the adrunio tool kit and the VISA drivers.  I also installed the IDE for the arduino and played around with it.  I used the simple blink program to test functionality of the Arudino IDE.  I then upladed the LVIFA_BASE.pde to the adrunio.
After launching LabView I searched for example programs and selected the Arduino Analog Read Pin.  I then go to run the example and get block diagram erros stating..
You have two or more cluster data types wired together, but the clusters have different kinds or numbers of elements.
Cluster error IO, a cluster of 3 elements,
conflicts with cluster error out, a cluster of 2 elements.
Is there anything I need to do to make the example work?  Obviously I have messed something up and after hours I trying to figure it out I decided to post for some help.
Thanks for your time.
(3,744 Views)
That is a very strange error and I don't have LabVIEW at the moment to look at it, so, meanwhile:  Try other examples.  I would recommend the blink example if there is one.
(3,352 Views)
Well my problem is solved.  I intstalled the software on my laptop and got everything to work as expected.  So I then reinstalled the Arduino toolkit on my desktop and everything works now.  Thanks for your help. I must have messed something up when I first started to find my way around labview.
(3,352 Views)
