LabVIEW Interface for Arduino Discussions
Can't get LIFA_Base to compile in Arduino 1.0.4
Nathan_B,
I'm using LabVIEW 2014 and followed the instruction and although all the other tabs open but i still I have the same problem:
'TKD2' was not declared in this scope
Could you help me please?
Message 21 of 25
(1,686 Views)
Did you try the XLoader I linked to earlier?  It should just upload the already compiled LIFA to an Arduino.  Of course this means you can't modify the code but most people looking to use LIFA don't need to.
Message 22 of 25
(1,686 Views)
Steps
1).Download link https://mega.co.nz/#F!C4EEzawT!kLDcTyQh_HeMtgOtnUCEiQ
and folder will be created LIFA_Base
2).Moves from the unzipped folder on the desktop program LIFA_Base.ino
3).Opens the program LabVIEWInterface.ino
4).Accepts the request to create folder.
5).Copy this files in the created folder: LabVIEWInterface.ino and also LabVIEWInterface.h
6).Opens the program LabVIEWInterface.ino
7).Then move the LabVIEWInterface.ino  and also LabVIEWInterface.h to the original carpeat called LIFA_Base
8).Then moves back the LIFA_Base.ino to LIFA_Base folder
9).LIFA_Base.ino opens and runs the program the Arduino
NOTE
You must have on your desktop all the files in the following folder
C: \ Program Files (x86) \ Arduino \ libraries \ RobotIRremote \ src
all files you have in the src folder should move to the desktop.
Message 23 of 25
(1,686 Views)
Makes no sense what U are writing.. Cant get it to work.
Move folders, open programs, copy. Can u make a better desscripson?
Message 24 of 25
(1,686 Views)
LIFA is no longer supported. If at all possible, you should use LINX
instead: http://www.labviewmakerhub.com/LINX
Message 25 of 25
(1,686 Views)
