LabVIEW Interface for Arduino Discussions
Can the Arduino Stepper Motor Example be used for L293D chip?
I am using the l293D motor driver IC and I wanted to know if its possible to use the arduino stepper motor example or stepper config/write functions with this driver? In the driver options for stepper config the options are: 2 pin, 4pin, EasyDriver, and Adafruit drivers. Is it possible to just chose one of these or is it not possible? I figured maybe the 4pin driver is the l293 since that has 4pins for control.. but Im not sure and also where do I specify which pins I am using on the arduino to connect to the l293..Anyone have any solution?
(6,410 Views)
The LIFA stepper motor example will not work with L293D stepper drivers.  The LIFA stepper motor example uses an Easy Driver.  With an Easy Driver  the Adruino board sends a step pulse and a direction signal to the driver for each step.  Whereas with a L293D the Arduino board must send an ordered sequence of step signals to a L293D  two H bridges.  See the full step sequence in Figure 2 in
<http://www.engr.mun.ca/~fifield/eng1040/Mechanical/Stepper_Motors.pdf> for the ordered sequence.
Arduino code is available at <https://learn.adafruit.com/adafruit-arduino-lesson-16-stepper-motors/overview> for using a L293D to drive a step motor.  You can not use LIFA with this code.  But you can replace the serial monitor mention in the example w2ith a Labview VI.
hrh212
(5,307 Views)
can I use a big easy driver instread of a easy driver?
(5,307 Views)
Yes you can use either the Easy Driver <https://www.sparkfun.com/products/12779>  ot the Big Easy
<https://www.sparkfun.com/products/12859> with LIFA.  The Big Easy has a higher current rating and can drive larger step motors than the Easy Driver.
hrh212
(5,307 Views)
