LabVIEW Interface for Arduino Discussions
Can you help me with a light sensor?
I need to make a light sensor  using labview and Arduino ,
as I can do to make it graph
(4,821 Views)
Podrías usar un LDR, con su arreglo correspondiente, y leer las variaciones a través de uno de los puertos análogos de tu Arduino. Después envías las lecturas a LabView y las graficas . Saludos.
You could use a LDR and read the meassures using the Arduino's analog port. Then, send the data to LabView to graph the values.
(4,256 Views)
Here is a link to web page showing how to measure light levels using  a LDR.
<https://learn.adafruit.com/photocells/using-a-photocell>
For this measurement use LINX.  The LINX example "Analog Read Example (serial Interface)" will plot its input signal as a function of time.
hrh212
(4,256 Views)
use a photocell and try using a resistor to control the voltage. then use the anolog read values to make an array and the draw the graph using graph function.
good luck.
(4,256 Views)
