LabVIEW Interface for Arduino Discussions
Change Data, SCK, and Latch Pins for SPI init
Does anyone know if it is possible to change the pin outs for the SPI init? The default are:
Arduino Pin 10 - SS - Latch Pin
Arduino Pin 11 - MOSI - Serial In
Arduino Pin 12 - MISO - Data Out
Arduino Pin 13 - SCK - Clock Pin
I already have some hard wired stuff on 11 and 12 and really don't want to move it.  I would like to be able to assign the pin numbers myself.  Anyone have any experience with this?
Bill
(5,502 Views)
I don't think there is a function to do this but you should be able to edit the pin numbers in pins_arduino.h
Kevin Fort
Principal Software Engineer
NI
(4,470 Views)
Am trying to give a answer for your query,
For previously defined pins, we can't change those IO configurations as we can becz those pin configuration functions already defined(specific function ex:as SEGMENT for LCD) for MCU, we can use other port pins ex:- PF.0,PF.1,PF.2 these bits of F port are used, you can use PF.3 to PF.15(defined pins in schematic).
with regards
Vidya yadav
Embedded engineer.
(3,609 Views)
