LabVIEW Interface for Arduino Discussions
Compactability
I am using lab view 2013.. i would like to know whether
NI LabVIEW Interface for Arduino Toolkit is compactable with Labview 2013
Message 1 of 8
(6,369 Views)
LabVIEW Interface for Arduino (LIFA) is compatible with LabVIEW 2013 but it is not recommended.  If you are not already using LIFA then it is recommended that you use LINX because LIFA is old and no longer officially supported.
Message 2 of 8
(5,432 Views)
Thanks for ur response. I would like to know whether is any ardunio IDE is required to run a program in LABVIEW . Or else oly labview blockdiagram alone is enough to program ardunio.
Message 3 of 8
(5,432 Views)
If you use LINX, you do not need the Arduino IDE.  If you use LIFA, you need the Arduino IDE to compile and upload the firmware to the Arduino.
Read the getting starting documents for LINX to learn how to use it:  https://www.labviewhacker.com/doku.php?id=learn:libraries:linx:getting_started
Message 4 of 8
(5,432 Views)
thank u... IDE is required for oly compiling the code right!! Thre is no need for coding in IDE or BLock diagram in labview will do???
Please attach few links of labview Arduino (windows) tutorial and examples
Message 5 of 8
(5,432 Views)
Yes dear LIFA work on labview 2013
Date: Sat, 12 Jul 2014 10:39:29 -0500
To: hafizsaeediqbal@yahoo.com
Subject: - Compactability
Community
Compactability
created by jlprasath in LabVIEW Interface for Arduino - View the full discussion
Reply to this message by replying to this email -or- go to the message on Community
Start a new discussion in LabVIEW Interface for Arduino by email or at Community
Message 6 of 8
(5,432 Views)
I posted the link to the Getting Started tutorial already above.  After you run the Firmware Wizard, it asks you if you want to run an example.  Click Yes.
Since it appears that you are new to LabVIEW, you should take some time to learn the basics of LabVIEW.  One good place to start is here.
Message 7 of 8
(5,432 Views)
If you are sticking with LIFA then normally you need the IDE for compiling but you could use this utility to simply upload an already built HEX file.
https://decibel.ni.com/content/thread/18700
Message 8 of 8
(5,432 Views)
