LabVIEW Interface for Arduino Discussions
Compiling error in Arduino
I was using Arduino, but i have tried first time to interface labview with arduino.
When i compiled LIFA, i get many errors, i dont know the reason for this.
Thanks alot
(5,456 Views)
I would recommend using LINX (it's the new version of LIFA).  http://www.labviewhacker.com/linx
You no longer need to compile the firmware, you simply need to use the Firmware Wizard to upload it.
If you want to use LIFA for some reason, you can find several other discussions about those errors here.
(4,803 Views)
Pls tell me that is the communication with the arduino board occurs with the same technique in labview as with other external devices in labview, i mean using the VISA functions or its different with using arduino with labview.
Regards
(4,803 Views)
Also i want to mention here is my function palette in block diagram shows the arduino's functions
(4,803 Views)
Both LIFA and LINX are API's for the Arduino that use NI VISA to communicate with the Arduino (assuming a USB connection).
(4,803 Views)
how can i upload firware LINX in my arduino nano ..........?????
(4,803 Views)
