LabVIEW Interface for Arduino Discussions
Controlling LED with Switch
Hello Engineers,
I am new to Labview, so please be patient with me 🙂
In this project, I am using one switch to turn LED On/Off.
I want to keep the LED On with one press and stays On when I release the switch, but when I press the switch the second time, I want the LED to turn off and stays off.
I did the design, but the only way that I could do it with is using for loop with specific length (the length of the for loop such as 10 iterations) when the case structure is true.
I attached the file and picture of the hardware which is only one switch and one LED.
Any improving idea would be appreciate it.
Thank you in advance
(5,648 Views)
A FOR loop that runs as fast as it can is not a timing device in any form. Look in the timing palette instead.
You probably only need to write to a Digital Write port when the value changes. No need to write the same value over and over.
Your code makes little sense. I would recommend to do a few more tutorials, look at the shipping examples, and then design it all as a simple state machine.
(5,615 Views)
Accepted by topic author Eisa_Alyaqoub
See if this can give you some ideas....
(5,611 Views)
Thank you so much altenbach, this is just what I am looking for.
Could you please explain how dose this Vi work ?
Really appreciate it
(5,582 Views)
There's not much to explain. You can right-click any element and launch the help. Place probes and run in execution highlighting to watch what happens. Do you understand some of it? Do you have a specific question?
(5,576 Views)
