LabVIEW Interface for Arduino Discussions
Controlling Speed of servo using lifa
hello
I have to drive servo using lifa it is working fine but the speed with which the servo moves is so fast now I am looking for a way to control the speed of the servo motor can i do this using LIFA
(4,074 Views)
I guess that depends on how you are currently running it.
(3,615 Views)
Thanks Nathan i m currently running it simply by using servo write angle vi and also try to run motor using pwm write vi. The specification of the motor i am using says it has speed of .18 per 60 degree is there any way this speed can b controlled. Literature says that the speed of servo motor can be changed by increasing the off time of the pwm and not changing the on time. It is also written in some place that the speed can be control by making changes in the LIFA_BASE firmware but what kind of changes?? if any one can give any idea i will be thankful
Regards
(3,615 Views)
Changing only one and not the other means it requires changing the frequency everytime you want to change the speed.  I'm not sure if that can be done.  Can you provide a link to this server motor's documentation?
(3,615 Views)
