LabVIEW Interface for Arduino Discussions
Creating a 3D waterfall graph with LIFA
I wonder is it possible to read the analog signals from my arduino and display in a 3D waterfall graph? I'm currently have 3 analog channels reading 3 seperate vibration signals. I was planning combine these signal and display it in the 3D waterfall graph in a FFT waveform. Any example or suggestion? thanks alot.
(3,930 Views)
A "waterfall" graph (whatever that is) would not be related to LIFA (afaik) but would be a basic LabVIEW thing.  LIFA simply gets you the data.
Is there something specific about this graph that makes you think it is related to LIFA?
If it truely isn't related to LIFA (which is what I would assume) then you would get better results by asking in the LabVIEW forums about a "waterfall graph".
(3,249 Views)
