LabVIEW Interface for Arduino Discussions
Difference Between arduino programming and lab view and android base?
hi,
i am new to arduino programming. i searched a lot about arduino programming in lab view and android.
1- what is the basic difference / limitation to program arduino in lab view?
2- when we program arduino in lab view is it downloaded in arduino or not?
3- can we use lab view base program of arduino with connection with lab view?
(4,941 Views)
Hello Asif,
I have the same questions. Do you find any thing helpful or not ?
Maaz
(4,809 Views)
1. It's not fully supported by NI, LINX is a third-party add-on that is supported by Digilent.
Support for LINX is primarily through https://www.labviewmakerhub.com/forums/.
2. Short answer no, LINX is an interpreter between your PC and the Arduino. It does not compile the LabVIEW code onto the Arduino from what I have researched. Your PC runs the LabVIEW end, magic happens in the LINX firmware, which then sends commands to the Arduino.
3. I don't understand your question.
Best Regards,
Sin | Electrical Engineer & Principal Consultant
(4,790 Views)
