LabVIEW Interface for Arduino Discussions
Digital Outputs At VI Startup
Two quick questions.
1. When I have my Uno plugged into the USB port and it powers on some of the digital ports are driven high while others are driven low.  Is there a way to change or configure this?
2. When labview executes and starts communications to the board the issues from question one are resolved as the board responds to labview.  Although I have noticed that some ports momentarly go high or low, not where they will end up, before they finally go to the settign that labview is driving them to.
Does anyone else experience this?  Any solutions to make all ports go low or high during the initial usb plugin?
Cheers
DN
(3,440 Views)
This was asked at least once before and I'm not entirely sure that it was successfully solved, although, the other person to reply said he had a solution that worked.  Try it out and see.
https://decibel.ni.com/content/message/41624
(3,139 Views)
