LabVIEW Interface for Arduino Discussions
Does anybody experienced any problem using VIPM?
Hi everyone!
It's been a while since I want to install the Arduino Package for LabVIEW, but I cannot get VIPM to work. I already tried an old version I had from last year as well as the newest available. The installation process shows no errors, but when I want to start VIMP app, sometimes it get stucked at the initial windows "Loading..." but nothing happens. Sometimes a Windows message appears saying something like : " The program stopped working correctly because of an error. Windows will close the program and will notify if a solution exists"... But no error number or code appears. Does anybody experienced the same issue?
I already checked the VIPM forum, but it seems that no real solution has been given to this so far (Apparently quite a few people get the same problem). In that forum someone stated that might be an issue with the processor, but I cannot find any sense to that.
I'm using Windows 8 PRO 64 bits by the way and just in case, my processor is an intel i7-3630QM
Thanks for any comment you can provide. I'm sure this will help more than just me.
DMDSync.
DMDsync
Message 1 of 11
(7,757 Views)
Just to add some more info to this thread in case anyone needs it, I'm attaching some links to a couple of threads regarding this issue on the VIPM forum.
http://forums.jki.net/topic/2065-crash-on-startup/page__p__5073__hl__crashes__fromsearch__1#entry507...
http://forums.jki.net/topic/2148-vipm-2013-crashes-when-booting/page__p__5261__hl__crashes__fromsear...
http://forums.jki.net/topic/2045-vipm-freezes-on-loading/page__p__4998__hl__loading__fromsearch__1#e...
http://forums.jki.net/topic/2127-this-software-is-a-bad-joke/page__p__5218__hl__%2Bvipm+%2Bwindows__...
I couldn't fix the issue yet but I am able to use the LIFCK and LVIFA packages thanks to the help of Sammy_K.
Regards!
DMDSync
DMDsync
Message 2 of 11
(5,750 Views)
So, your problem is not related to LIFA then, correct?
Message 3 of 11
(5,750 Views)
That's right, the problem is just using VIPM to download and install the LabVIEW packages.
Since there was not another "official" way to install LIFA I did it manually and it is all working fine so far.
DMDSync
DMDsync
Message 4 of 11
(5,750 Views)
Im currently having the same problem, has this been resolved ?
Message 5 of 11
(5,750 Views)
SaintJohn,
I don't think this has been resolved.  Can you post a MAX Technical Report so we can compare your system to DMDsync's.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019hceCAA&l=en-US
Someone should probably start a thread on the JKI forums to get them to help out with this.
-Sam K
Message 6 of 11
(5,750 Views)
I'm will try in some minutes another VIPM.exe file to see if it fix the issue. I will let you know as soon as I can.
Regards.
DMDSync-
DMDsync
Message 7 of 11
(5,750 Views)
Ok. I assume you have the same system that I have (Windows 8 x64), so I will give you something you might want to try in order to solve the problem:
First you should download this file and replace the old VI Package Manager.exe with the one from the zip file ( It is located here: C:\Program Files (x86)\JKI\VI Package Manager). After that, if you start VIPM, this windows might appear. I tried a couple of Run-Time Engine versions but the one that worked for me was the Run-Time Engine 2013 x32. I tried the RT Engine 2013 x64, because I thought it should match my Windows (x64), but apparently it has to match the LabVIEW (x32). You can find the RT Engine that I downloaded in this link.
I'll wait for your comments.
Regards
DMDSync-
DMDsync
Message 8 of 11
(5,750 Views)
Hi SaintJohn!
Were you able to try the solution I posted? Please let me know so I am sure this work not only for me.
Cheers.
DMDSync-
DMDsync
Message 9 of 11
(5,750 Views)
Hey 🙂
Thanks for the reply, i tried to download the file but when i get to the web site it says the file has been removed.
Could you repost it please.
Thank you
Message 10 of 11
(5,750 Views)
