LabVIEW Interface for Arduino Discussions
ERROR 5002 with UNO board on Init
did you guys fix this problem, i had the same issue with mine and i fixed it and it works now.  I had to go into the int.vi and adjust the timeout error time and make it longer.  of course you have to make sure your baud setting match and if that didnt fix your issue, increase the timeout.  it is set at like 100ms of something.  i went ridiuculiously high and make it 100000ms just to see if i could communicate.  once my computer was able to communicate to is i was able to back down the timeout to 1000ms and it continues to work.  If you have any questions let me know and i can take screen shots if you guys still need to fix the issue.
Message 21 of 26
(3,401 Views)
hi,meryouma
       do you have solved your problem? i meet the same problem, could you tell me? thank you very much
Message 22 of 26
(3,401 Views)
SOLVED!!
Change the baud rate defined in the LabVIEWinterface.h arduino header file (in LIFA firmware) to 9600.
#define DEFAULTBAUDRATE 115200
to
#define DEFAULTBAUDRATE 9600
Cross check your active com port and board chosen. Run the model. Good Luck all.
Message 23 of 26
(3,310 Views)
--SOLVED--
I would like for everyone who reads this post to know that I have solved the 5002 issue. You can find the post for the solution here.
Good luck!
-tStark
Message 24 of 26
(3,248 Views)
I solved the problem and i knew !!! Euréka.
In fact, the arduino board can't work on reading and writting in the same time. It's right, arduino programs is séquential. You have to create a sequential program where the reading and writing opérations following.
Message 25 of 26
(3,138 Views)
3 days of wasted time; error 5003, error 5002,
Pretty graphs and Virtual Instruments, but Can't lit up a single LED until extra elephantware NI VISA, VI Package Manager, LIFA Base and now LINX is installed. Hate LabView for this reason. Maybe i'm getting old, but this is too much trouble for a thing anyone can do in 5 minutes with Arduino alone.
Thanks for the advice. Hope LINX is better option.
Message 26 of 26
(2,345 Views)
