LabVIEW Interface for Arduino Discussions
Editing firmware to reduce clock speed
So I have decided to use the Arduino on my bachelor's project for measuring power produced by an implantable glucose fuel cell. I chose the Arduino because of the convenient LabVIEW interface software.
One of my main problems have been getting accurate enough readings. I preferably need to measure changes as low as 10 microvolts. I have been experimenting with the analog reference voltage (AREF) and got this down to 0.57 Volts before it stopped measuring. This was with the LIFA firmware. When I made a test program witht the Arduino sketch program, I managed to get the AREF down to 0.22 Volts by reducing the clock speed. I suspect the reason why the AREF is affected by the clock speed is due to the Arduino using successive approximation in the DAC.
I tried editing the LIFA firmware to do the same as my sketch program, but without success. I think my added commands are being overwritten somewhere, but I don't know where. What I did was entering this into the void setup() section:
void setup()
  // Initialize Serial Port With selcted baudrate
      Serial.begin(38400*2);
      // Clock prescale
      clock_prescale_set(clock_div_64);
      // Clock prescaler, "111" = div128, "000" = div2
      ADCSRA |= (1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
Does anyone know where this is overwritten or have an alternative solution to my problem?
(I could of course try with a higher resolution DAC, but then I would have to edit the firmware again)
(3,955 Views)
I would suggest using a higher resoltion DAC.  They are relativly cheap and would be a much better solution at the end of the day (although some additional work upfront).
-Sam K
LIFA Developer
(3,473 Views)
