LabVIEW Interface for Arduino Discussions
Error compiling LIFA
HELLO,
I,am trying to load the LIFA into my arduino uno R3 and I always get the sme error from the IDE:
Arduino: 1.6.6 Hourly Build 2015/10/01 05:42 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LVIFA_Base.ino:26:0:
LabVIEWInterface.h:33: error: redefinition of 'unsigned char currentCommand [15]'
unsigned char currentCommand[COMMANDLENGTH];    // The Current Command For The Arduino To Process
In file included from C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LVIFA_Base.pde:26:0:
LabVIEWInterface.h:33: error: 'unsigned char currentCommand [15]' previously declared here
LabVIEWInterface.h:35: error: redefinition of 'unsigned char acqMode'
unsigned char acqMode;
LabVIEWInterface.h:35: error: 'unsigned char acqMode' previously declared here
LabVIEWInterface.h:36: error: redefinition of 'unsigned char contAcqPin'
unsigned char contAcqPin;
LabVIEWInterface.h:36: error: 'unsigned char contAcqPin' previously declared here
LabVIEWInterface.h:37: error: redefinition of 'float contAcqSpeed'
float contAcqSpeed;
LabVIEWInterface.h:37: error: 'float contAcqSpeed' previously declared here
float contAcqSpeed;
LabVIEWInterface.h:38: error: redefinition of 'float acquisitionPeriod'
float acquisitionPeriod;
LabVIEWInterface.h:38: error: 'float acquisitionPeriod' previously declared here
LabVIEWInterface.h:39: error: redefinition of 'float iterationsFlt'
float iterationsFlt;
LabVIEWInterface.h:39: error: 'float iterationsFlt' previously declared here
LabVIEWInterface.h:40: error: redefinition of 'int iterations'
int iterations;
LabVIEWInterface.h:40: error: 'int iterations' previously declared here
int iterations;
LabVIEWInterface.h:41: error: redefinition of 'float delayTime'
float delayTime;
LabVIEWInterface.h:41: error: 'float delayTime' previously declared here
float delayTime;
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.ino:138:60: warning: left shift count >= width of type [enabled by default]
       duration=(command[8]+  (command[7]<<8)+ (command[6]<<16)+(command[5]<<24));
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.ino:138:77: warning: left shift count >= width of type [enabled by default]
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: At global scope:
LabVIEWInterface:29: error: redefinition of 'AF_Stepper motor1'
   AF_Stepper motor1(200, 1);
LabVIEWInterface:29: error: 'AF_Stepper motor1' previously declared here
LabVIEWInterface:30: error: redefinition of 'AF_Stepper motor2'
   AF_Stepper motor2(200, 2);
LabVIEWInterface:30: error: 'AF_Stepper motor2' previously declared here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void forwardstep1()':
LabVIEWInterface:34: error: redefinition of 'void forwardstep1()'
   void forwardstep1() {
LabVIEWInterface:34: error: 'void forwardstep1()' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void backwardstep1()':
LabVIEWInterface:37: error: redefinition of 'void backwardstep1()'
   void backwardstep1() {
LabVIEWInterface:37: error: 'void backwardstep1()' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void forwardstep2()':
LabVIEWInterface:41: error: redefinition of 'void forwardstep2()'
   void forwardstep2() {
LabVIEWInterface:41: error: 'void forwardstep2()' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void backwardstep2()':
LabVIEWInterface:44: error: redefinition of 'void backwardstep2()'
   void backwardstep2() {
LabVIEWInterface:44: error: 'void backwardstep2()' previously defined here
LabVIEWInterface:48: error: redefinition of 'AccelStepper steppers [8]'
   AccelStepper steppers[8];  //Create array of 8 stepper objects
LabVIEWInterface:48: error: 'AccelStepper steppers [8]' previously declared here
LabVIEWInterface:54: error: redefinition of 'unsigned int retVal'
unsigned int retVal;
LabVIEWInterface:54: error: 'unsigned int retVal' previously declared here
LabVIEWInterface:55: error: redefinition of 'int sevenSegmentPins [8]'
int sevenSegmentPins[8];
LabVIEWInterface:55: error: 'int sevenSegmentPins [8]' previously declared here
LabVIEWInterface:56: error: redefinition of 'int currentMode'
int currentMode;
LabVIEWInterface:56: error: 'int currentMode' previously declared here
int currentMode;
LabVIEWInterface:57: error: redefinition of 'unsigned int freq'
unsigned int freq;
LabVIEWInterface:57: error: 'unsigned int freq' previously declared here
unsigned int freq;
LabVIEWInterface:58: error: redefinition of 'long unsigned int duration'
unsigned long duration;
LabVIEWInterface:58: error: 'long unsigned int duration' previously declared here
LabVIEWInterface:59: error: redefinition of 'int i2cReadTimeouts'
int i2cReadTimeouts = 0;
LabVIEWInterface:59: error: 'int i2cReadTimeouts' previously defined here
LabVIEWInterface:60: error: redefinition of 'char spiBytesToSend'
char spiBytesToSend = 0;
LabVIEWInterface:60: error: 'char spiBytesToSend' previously defined here
LabVIEWInterface:61: error: redefinition of 'char spiBytesSent'
char spiBytesSent = 0;
LabVIEWInterface:61: error: 'char spiBytesSent' previously defined here
LabVIEWInterface:62: error: redefinition of 'char spiCSPin'
char spiCSPin = 0;
LabVIEWInterface:62: error: 'char spiCSPin' previously defined here
char spiCSPin = 0;
LabVIEWInterface:63: error: redefinition of 'char spiWordSize'
char spiWordSize = 0;
LabVIEWInterface:63: error: 'char spiWordSize' previously defined here
LabVIEWInterface:64: error: redefinition of 'Servo* servos'
Servo *servos;
LabVIEWInterface:64: error: 'Servo* servos' previously declared here
Servo *servos;
LabVIEWInterface:65: error: redefinition of 'byte customChar [8]'
byte customChar[8];
LabVIEWInterface:65: error: 'byte customChar [8]' previously declared here
byte customChar[8];
LabVIEWInterface:66: error: redefinition of 'LiquidCrystal lcd'
LiquidCrystal lcd(0,0,0,0,0,0,0);
LabVIEWInterface:66: error: 'LiquidCrystal lcd' previously declared here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void setMode(int)':
LabVIEWInterface:68: error: redefinition of 'void setMode(int)'
void setMode(int mode)
LabVIEWInterface:68: error: 'void setMode(int)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'int checkForCommand()':
LabVIEWInterface:74: error: redefinition of 'int checkForCommand()'
int checkForCommand(void)
LabVIEWInterface:74: error: 'int checkForCommand()' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void processCommand(unsigned char*)':
LabVIEWInterface:103: error: redefinition of 'void processCommand(unsigned char*)'
void processCommand(unsigned char command[])
LabVIEWInterface:103: error: 'void processCommand(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde:138:60: warning: left shift count >= width of type [enabled by default]
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde:138:77: warning: left shift count >= width of type [enabled by default]
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void writeDigitalPort(unsigned char*)':
LabVIEWInterface:541: error: redefinition of 'void writeDigitalPort(unsigned char*)'
void writeDigitalPort(unsigned char command[])
LabVIEWInterface:540: error: 'void writeDigitalPort(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void analogReadPort()':
LabVIEWInterface:560: error: redefinition of 'void analogReadPort()'
LabVIEWInterface:559: error: 'void analogReadPort()' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void sevenSegment_Config(unsigned char*)':
LabVIEWInterface:592: error: redefinition of 'void sevenSegment_Config(unsigned char*)'
void sevenSegment_Config(unsigned char command[])
LabVIEWInterface:591: error: 'void sevenSegment_Config(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void sevenSegment_Write(unsigned char*)':
LabVIEWInterface:603: error: redefinition of 'void sevenSegment_Write(unsigned char*)'
void sevenSegment_Write(unsigned char command[])
LabVIEWInterface:602: error: 'void sevenSegment_Write(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void spi_setClockDivider(unsigned char)':
LabVIEWInterface:612: error: redefinition of 'void spi_setClockDivider(unsigned char)'
void spi_setClockDivider(unsigned char divider)
LabVIEWInterface:611: error: 'void spi_setClockDivider(unsigned char)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void spi_sendReceive(unsigned char*)':
LabVIEWInterface:643: error: redefinition of 'void spi_sendReceive(unsigned char*)'
void spi_sendReceive(unsigned char command[])
LabVIEWInterface:642: error: 'void spi_sendReceive(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void syncLV()':
LabVIEWInterface:694: error: redefinition of 'void syncLV()'
void syncLV()
LabVIEWInterface:693: error: 'void syncLV()' previously defined here
void syncLV()
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'unsigned char checksum_Compute(unsigned char*)':
LabVIEWInterface:704: error: redefinition of 'unsigned char checksum_Compute(unsigned char*)'
unsigned char checksum_Compute(unsigned char command[])
LabVIEWInterface:703: error: 'unsigned char checksum_Compute(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'int checksum_Test(unsigned char*)':
LabVIEWInterface:715: error: redefinition of 'int checksum_Test(unsigned char*)'
int checksum_Test(unsigned char command[])
LabVIEWInterface:714: error: 'int checksum_Test(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void AccelStepper_Write(unsigned char*)':
LabVIEWInterface:730: error: redefinition of 'void AccelStepper_Write(unsigned char*)'
   void AccelStepper_Write(unsigned char command[]){
LabVIEWInterface:729: error: 'void AccelStepper_Write(unsigned char*)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void sampleContinously()':
LabVIEWInterface:756: error: redefinition of 'void sampleContinously()'
LabVIEWInterface:755: error: 'void sampleContinously()' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void finiteAcquisition(int, float, int)':
LabVIEWInterface:775: error: redefinition of 'void finiteAcquisition(int, float, int)'
void finiteAcquisition(int analogPin, float acquisitionSpeed, int numberOfSamples)
LabVIEWInterface:774: error: 'void finiteAcquisition(int, float, int)' previously defined here
C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base\LabVIEWInterface.pde: In function 'void lcd_print(unsigned char*)':
LabVIEWInterface:798: error: redefinition of 'void lcd_print(unsigned char*)'
void lcd_print(unsigned char command[])
LabVIEWInterface:797: error: 'void lcd_print(unsigned char*)' previously defined here
exit status 1
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
PLEASE help me fix it because it is driving me crazy...
(10,064 Views)
LIFA was developed with an older version of the Arduino IDE.  You need to use either version 1.0.6 or older or use LINX.
hrh212
(7,945 Views)
I used the 1.0.6 version and it gave me the same error!
HELP
(7,945 Views)
Have you tried LINX?  http://www.labviewmakerhub.com/linx
(7,945 Views)
When I try to compile LIFA_Base now with an older version of the Arduiino IDE I get errors.  Whereas last spring I successfully compiled LIFA_Base.  I will need more time  to find the bug ro be able to answer your question
hrh212
(7,945 Views)
The problem is solved, it turned out that there were two additional files with extension .ino in the firmware, when I deleted them the firmware uploaded just fine with no error. Thank you for your help I can now begin my projects
(7,945 Views)
Were you able to solve it?
(5,481 Views)
