LabVIEW Interface for Arduino Discussions
Error en LIFA_Base
C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:60: warning: left shift count >= width of type [-Wshift-count-overflow]
duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24));
C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:77: warning: left shift count >= width of type [-Wshift-count-overflow]
C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino: In function 'sevenSegment_Config(unsigned char*)':
C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:632:41: warning: iteration 7 invokes undefined behavior [-Waggressive-loop-optimizations]
sevenSegmentPins[(i-1)] = command[i];
C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:629:17: note: containing loop
for(int i=2; i<10; i++)
C:\Users\MIKE & BETO\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino\main.cpp: In function 'main':
El Sketch usa 17974 bytes (55%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 1104 bytes (53%) de la memoria dinámica, dejando 944 bytes para las variables locales. El máximo es 2048 bytes.
(3,707 Views)
Buenos días,
Yo dispongo de una placa arduino UNO R3 y me estoy encontrando con el mismo problema, he cambiado varias veces de puerto USB. ¿has podido solucionar el problema?
(3,337 Views)
