LabVIEW Interface for Arduino Discussions
Error with firmware compiling
I cannot compile the firmware, I attached the file with the image with the error, I have tried opening all the files in the folder but it says that sketch is too big, so I needed some help or suggestions on how to compile the firmware in order to use labVIEW with arduino
(4,851 Views)
Hi yasu7,
Do you upgrade the latest version for Labview interface for Arduino version 2.1.1.69?
(3,794 Views)
Yes it's ugraded to the latest version
(3,794 Views)
Something goofy is going on here. When you open the base sketch for arduino it should open several other files including the header files which declare a lot of the variables it looks like you are missing. Are those files in your firmware directory under lvlib or are they not downloaded at all?  Which board are you compiling for?
Kevin Fort
Principal Software Engineer
NI
(3,794 Views)
